Show information about the EVPN instance table.
| bgp | Specifies BGP. |
| evpn | Specifies Ethernet VPN (RFC 7432). |
| evi | Shows the EVPN instance table. |
| evi-index | Specifies the EVI index. |
| vni | Specifies a particular virtual network identifier. |
| vni | Selects the VNI. Range is 1 to 16,777,215. |
N/A.
Each EVPN instance represents a VLAN in a virtual network. In this implementation, there must be a 1-to-1 relationship between VLAN and VNI.
The following example displays the currently active EVPN EVI instances:
# show bgp evpn evi
Flgs EVI-Idx Name VNI Local VTEP RD Import RTs Export RTs
* 190 10000 1.1.1.102 1.1.1.102:190 64716:16787216 64716:16787216
* 1020 101020 1.1.1.102 1.1.1.102:1020 64716:16878236 64716:16878236
* 3500 111103 1.1.1.102 1.1.1.102:3500 64716:16888319 64716:16888319
* 4089 101021 1.1.1.102 1.1.1.102:4089 64716:16878237 64716:16878237
*SM 125 MktEvi 777 1.1.1.102 65535:1 25:16777993 25:16777993
25:100 25:100
SM EngEvi 884 1.1.1.102 1:65535 20:1 20:1
Flags: (*) Entry is active, (S) Entry is statically configured. (M) RD
and RT are manually configured
RD: Route distinguisher
RT: Route target – See RFC 8365 section 5.1.2.1 for details on automatically
]generated RT decoding instructions.
Some static entries may have multiple route target sets.
These are listed in rows immediately following the initial row
for the EVI-Idx.
Total Displayed: 6 Static: 2 Dyn: 4
This command was first available in ExtremeXOS 30.2.
This command is available on platforms that support the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and which licenses support the BGP feature, see the Switch Engine v33.1.1 Licensing Guide document.
